Liketosmash Posted January 22, 2020 Share Posted January 22, 2020 Ran into an issue installing a front driveshaft on my Comanche last night. A bit of history, the 1987 Comanche started as a 2wd and I converted it over to 4wd using a 1988 donor Cherokee. The donor Cherokee was missing the front driveshaft but I found one from a 1989 Cherokee and figured problem solved. Went to install the front driveshaft last night and .... its too long. I have now learned that the front driveshaft on an automatic Cherokee is longer than the driveshaft on a manual Cherokee. So I'm in search of a front driveshaft for a manual transmission Cherokee or I might get it cut down when I get the rear driveshaft cut down. As I have run into so many small differences on the various years just checking in here to see if there are any other driveshaft variances I need to look out for. Is the manual front driveshaft the same for all manual transmissions or are there several options? Quick specs on what I have: 1987 Comanche 1988 Cherokee 4.0L engine from 1988 Cherokee BA10 manual 5 speed transmission from 88 Cherokee 1989 Cherokee front driveshaft Link to comment Share on other sites More sharing options...
derf Posted January 22, 2020 Share Posted January 22, 2020 I can't say for sure but it seems like there are a lot of Ba10 specific things. A driveshaft may be one of those things. Driveshafts are easy to shorten. It may be cheap to just take the shaft to a shop and have them do that for you and balance it again. That is, if there's a shop anywhere near you that can do it. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 22, 2020 Share Posted January 22, 2020 An auto trans (AW4) is longer by about 1" than a BA10 and AX15. The front drive shaft for an auto is longer than a manual trans DS. Link to comment Share on other sites More sharing options...
