500 MJ Posted January 16, 2020 Posted January 16, 2020 This one is located at Jack's Auto Ranch in Concord, WI. The truck was still there when I was last at the yard in the fall of 2019. These pictures are from 2016, even at in 2016 the VIN was not readable on the dash, but I found this picture of the under-hood VIN from all those years ago so I am now able to post this one up. The driver's door is unable to be opened due to the tree next to it.
eaglescout526 Posted January 16, 2020 Posted January 16, 2020 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AJZ CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 10/27/85 Body code TP62 Some good parts still on it
eaglescout526 Posted January 16, 2020 Posted January 16, 2020 1 minute ago, High2by said: Such a waste of parts...It hurts the soul. It has a good door bezel for ya.
500 MJ Posted January 16, 2020 Author Posted January 16, 2020 This one is still in the yard, I'll probably be back when the weather is nicer out. What do you see that you need? FYI - I'd need to take a chainsaw with me to open the driver's door up...
High2by Posted January 16, 2020 Posted January 16, 2020 Just now, 500 MJ said: This one is still in the yard, I'll probably be back when the weather is nicer out. What do you see that you need? FYI - I'd need to take a chainsaw with me to open the driver's door up... The door handle bezels, if they are in decent shape. Especially the drivers side. The cups and handles I have are ok and I got new lock buttons, thanks to eaglescout.
eaglescout526 Posted January 16, 2020 Posted January 16, 2020 Cargo light and 2.5Litre nameplate should be snagged.
500 MJ Posted January 16, 2020 Author Posted January 16, 2020 9 minutes ago, High2by said: The door handle bezels, if they are in decent shape. Especially the drivers side. The cups and handles I have are ok and I got new lock buttons, thanks to eaglescout. So these are what you are after for both sides? I might have a set of those in my garage, I will check. Otherwise they should be easy to source from any yard in the area here. Let me know if you get a set, otherwise I will plan to snag some next time I am out...
500 MJ Posted January 16, 2020 Author Posted January 16, 2020 Just now, eaglescout526 said: Cargo light and 2.5Litre nameplate should be snagged. I have the light. I'll snag the badge next time.
High2by Posted January 16, 2020 Posted January 16, 2020 1 minute ago, 500 MJ said: So these are what you are after for both sides? I might have a set of those in my garage, I will check. Otherwise they should be easy to source from any yard in the area here. Let me know if you get a set, otherwise I will plan to snag some next time I am out... Yes, that's what I need. No power window or lock switch. I'll shoot you a PM
eaglescout526 Posted January 16, 2020 Posted January 16, 2020 1 minute ago, 500 MJ said: I have the light. I'll snag the badge next time. Ah good score. Sounds good.
High2by Posted January 16, 2020 Posted January 16, 2020 6 minutes ago, eaglescout526 said: Ah good score. Sounds good. I know this is off topic but can one of these lights be put on a truck that didn't come with it?
eaglescout526 Posted January 16, 2020 Posted January 16, 2020 6 minutes ago, High2by said: I know this is off topic but can one of these lights be put on a truck that didn't come with it? Sure can! I did it and its in my build.
High2by Posted January 16, 2020 Posted January 16, 2020 1 minute ago, eaglescout526 said: Sure can! I did it and its in my build.
500 MJ Posted October 27, 2020 Author Posted October 27, 2020 Visited this truck again yesterday. Tailgate was gone when I got there. Pulled the headliner out of it as well as the B pillar trims, upper rear cab trim and other interior misc. pieces. Removed the seat for ease of getting to the headliner, seat is in poor shape so I just left it in the bed.
