Throttle Position and Crank Position Sensors
The TPS is pretty simple.  Two torx screws attach it to the throttle body.  You will need to adjust it to function properly.  See Cruiser's Tips for the steps.  You will need a multi-meter to set it.
The CPS is bolted to the top of the bell housing.  You will need some ratchet extensions and some patients.  Also, see Cruiser's Tips.
