help I bought a 1986 mj running rough pulled it in and put a fuel pump on it also a new muffler and it has not fired sence so I replaced the wiring harness on motor still nothin any ideals to help I also replaced icu coil distibuter cap and please excuess the spelling
thank you
cresley
Alrighty. If you need help, post in the tech what your problem is. This area is for the registry of all our trucks. Not everyone is gonna look at these to help you out with your problem. I'll gladly post a build date and sheet for you.
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT
-ZZ
BAC 75 AMP ALTERNATOR
BCQ Battery - 750 Amp Maintenance Free
CGX Head Restraints-Outboard Seating, RR
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
DCK 4SPD MANUAL TRANS - AISIN SEIKI
EPD ENGINE - 2.5L I4 TBI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
GSC MIRROR - RIGHT BLACK
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JFH TACHOMETER - MECH
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 20 GAL FUEL
NMB ENGINE COOLING - STANDARD DUTY
SBA POWER STEERING
Build date: 8/28/85
Body code: JL62
Click on your username (upper right hand corner) and go to Account Setting, then go to Signature. Put your vehicle Year and Engine there.
