windshield wipers not moving?
Check the ground and if it is intermittent wipers, unplug the black box module/governor and plug the two ends together and see if you have wipers. If not then the motor could be bad or need regrease or the linkage bushings fell apart. So there’s a few things to check.
Mine suddenly stopped on me once.  Motor continued to make some noise, so I figured it likely wasn't the problem.  Turns out, parts of the wiper motor assembly came apart.  There are 3 or 4 bolts that hold it all together, which overtime became loose and at least one totally backed out of its hole.  It was essentially falling apart.
Check out this pic-heavy tread to learn a little more about what Jeep put together for our wiper systems:
