54bobby Posted November 11, 2019 Share Posted November 11, 2019 so, my daughter went to go to work and the truck started fine. she pulls the floor shifter into gear and the lever travels through all the gears but won't engage any of them. the shifter seams like it is not engaging any of the notches. i don't have to hold the button on the side in and she still travels through all gears. this was an all of a sudden thing with zero prior symptoms. i'm working 16 hour shifts so if someone can give me a jump start on what i'm looking for it will save me a couple hours sleep on diagnosing the problem. thanks in advance. Link to comment Share on other sites More sharing options...
jdog Posted November 11, 2019 Share Posted November 11, 2019 pull the shifter plate and make sure the cable is still connected, what it sounds like is it came loose Link to comment Share on other sites More sharing options...
54bobby Posted November 11, 2019 Author Share Posted November 11, 2019 6 hours ago, jdog said: pull the shifter plate and make sure the cable is still connected, what it sounds like is it came loose I'm hoping that is the case. What would be my worse case scenario? Link to comment Share on other sites More sharing options...
omega_rugal Posted November 11, 2019 Share Posted November 11, 2019 1 hour ago, 54bobby said: What would be my worse case scenario? that the manual valve is broken, but sounds like the cable is detached Link to comment Share on other sites More sharing options...
54bobby Posted November 12, 2019 Author Share Posted November 12, 2019 The cable is unattached from the trans linkage nipple. The hayes manual says release the locking clamp , attach the cable then depress the clamp to lock in place. Question is,where is that locking clamp? And is it accessible from beneath or above in the console. Link to comment Share on other sites More sharing options...
jdog Posted November 12, 2019 Share Posted November 12, 2019 The locking clamp should be at the end of the cable where it mounts to the trans if I recall correctly Stock 1988 swb 4.0 ax15 np 231. Link to comment Share on other sites More sharing options...
