Question about WJ LCA install
Few months back the truck got a small puck & shackle lift and shod with 31" BFG's
Tires were rubbing the stock LCA's - not undriveable, but really annoying when maneuvering a trailer around.
Bought a new set of WJ LCA's off of Rockauto - they are pretty much a direct swap except you have to grind down the ends a bit - I used an abrasive cut-off wheel mounted on miter saw, took a few minutes to shave off a 1/4 inch or so on all sides.
Question:  The WJ LCA's have a big oval shaped bushing on one end (the stock LCA's had round on both ends) - the arms seemed to mount either way, so I rolled the dice and put the oval bushing on the axle side.....
Does it matter?
Fixed the rubbing problem - so happy even if I have to take them back off and reverse.
26 minutes ago, Pete M said:
If I remember right, the big oval goes to the rear.   :L:
Did it bass-ackwards then - damn.
Going to live with it for now as is - only using the truck for foul weather this year anyway (if it snows or gotta go into the mountains)
Man, had a 50/50 shot - if it wasn't for bad luck.....
