1J7FT26E2LL246371
HunterB
Here’s my 1990 Jeep Comanche, bought it stock about 3 years ago, 2.5l with a 2wd AX4. The after pic is how it sits now, specs on build:
9.5” Rusty’s spring with 2” puck, roughly country long arm crossmember with custom made long arms out of 1.5x.250 DOM, rear is a Rusty’s 4” lift spring over axle. It also has rough country track bar drop down bracket and an adjustable track bar with a custom OTA track bar bracket. Rear shock tabs were re welded higher on the axle for clearance. Rear axle is an 8.25 out of a 96, front is a D30 out of an 86 I believe, regreared to 4.88, trans is a 4x4 AX5 out of an 86 Cherokee
*X2 TRIM STYLE X2 - VINYL BENCH
-SA Charcoal
169 Zone 69-Phoenix
1AA U.S. Dealer Retail
4HA Special Scheduling Condition I
4XA Air Conditioning Bypass
ALA SE Decor Group
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DCK 4SPD MANUAL TRANS - AISIN SEIKI
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EPD ENGINE - 2.5L I4 TBI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KDB STRIPE/BADGE/MOLDING
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SAA Manual Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z56 Left Front Spring Group Vi
Z75 Right Front Spring Group V
Woah! An AZ truck! Neat!
Build Date: 4/11/90
Body Code:TL61
  • 1 year later...
