Flare bracket mod
I was thinking about welding some bolts to these but I'm not the best welder on thin metal. Then I came up with the idea of drilling and tapping the old bolt heads after grinding the stud part off. I will use at least red locktite to hold the bolts in. Before, i had fender washers on bolts and while it works it's not ideal. Also using stainless bolts. Good idea or no?
