PCB part help
kook911
This board is for my gate opener. One piece burnt up and I need to replace it. I don’t know what the part is called. The part that I need to name is the little square. It has a white bar on one side.  The numbers are 10 16A. Any help will be greatly appreciative.
First pic shows the burnt part. The other two show good parts.
Not seeing what you need with a quick Google search.  May be able to find a schematic for the gate opener or info if that's a common failure.  You don't necessarily need a surface mount replacement but ideally you would   Could also contact the manufacturer and see if they will give you any info on it.
