Raven Posted September 13, 2019 Share Posted September 13, 2019 I’m just curious what spring packs. They’re on a short bed MJ. Link to comment Share on other sites More sharing options...
Dammerung Posted September 13, 2019 Share Posted September 13, 2019 I’m just curious what spring packs. They’re on a short bed MJ. I believe so. That straight leaf on the bottom of the pack is what’s clueing me in. That usually signifies higher rate towing suspension.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
WahooSteeler Posted September 13, 2019 Share Posted September 13, 2019 Not factory MT's at least. Could be an aftermarket set based on it having a military wrap on the frame side mount. The other end of the second leaf under the main is not tapered which would usually indicate and add-a-leaf, but I have never seen an AAL with a military wrap. May be a bastard pack someone put together. Link to comment Share on other sites More sharing options...
Dammerung Posted September 13, 2019 Share Posted September 13, 2019 Not factory MT's at least. Could be an aftermarket set based on it having a military wrap on the frame side mount. The other end of the second leaf under the main is not tapered which would usually indicate and add-a-leaf, but I have never seen an AAL with a military wrap. May be a bastard pack someone put together. More than likely this ^. Comanches are not my specialty.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Raven Posted September 13, 2019 Author Share Posted September 13, 2019 I thought MT’s had two overload springs on the bottom? I’ve bought three MJ’s and all have the single overload leaf. Link to comment Share on other sites More sharing options...
Raven Posted September 13, 2019 Author Share Posted September 13, 2019 BTW... I did brush off the other pack to check for numbers to see if it was aftermarket. No numbers etc.. Link to comment Share on other sites More sharing options...
Eagle Posted September 13, 2019 Share Posted September 13, 2019 1 hour ago, WahooSteeler said: Not factory MT's at least. Could be an aftermarket set based on it having a military wrap on the frame side mount. The other end of the second leaf under the main is not tapered which would usually indicate and add-a-leaf, but I have never seen an AAL with a military wrap. May be a bastard pack someone put together. ^^^ This, plus the Metric Ton package wasn't offered with the shortbeds, only on the longneds. My vote goes to aftermarket springs. Link to comment Share on other sites More sharing options...
Eagle Posted September 13, 2019 Share Posted September 13, 2019 41 minutes ago, Raven said: I thought MT’s had two overload springs on the bottom? I’ve bought three MJ’s and all have the single overload leaf. Could be either 4+1 or 3+2 Link to comment Share on other sites More sharing options...
