The automatic transmission on my 1988 Comanche is not shifting into 2nd or 3rd.  I think I need to replace the 3 solenoids the filter and gasket.  I belie3ve the transmission is a AW 30-40LE but not sure.  Does anyone know a supplier who has these parts.
Thanks,
Mac
83504044(x1 needed) and 83504043(x2 needed) are your solenoid numbers. Catalogue doesn't say which is which
Filter kit is this number: 5083122AA. Don't know who Chryslers supplier is. Probably Aisin or Warner as it is a joint project between the two companies for AW4.
Other than the solenoids, what else could be causing the problem of not shifting into 2nd or 3rd?  Do I need to worry about the TCU?
