Pitman arms
I need a different one and I'm coming up blank.  The SJ Wagoneer arm I'm using does not have quite enough drop.  An XJ one has too much.
TJ arms have more drop than an XJ, IIRC.  Is the ZJ or WJ the same as the XJ, or more or less drop?
What else is out there?  Looked at the Scout II, but it looks too long (I'm already tight with the Wagoneer arm).
Somewhere there used to be a great comparison picture of all the commonly available pitman arms.  I'm afraid it is lost to photosuckit.
