Manche757 Posted July 25, 2019 Share Posted July 25, 2019 I am sure this has been dealt with but I am still not clear about it. Are fuse panels for all MJ years the same? Which year XJ panels can be used to replace an 87MJ, 4.0, 5 speed and also in an 89MJ, 4.0, 5 speed? Link to comment Share on other sites More sharing options...
Manche757 Posted July 25, 2019 Author Share Posted July 25, 2019 I bought two fuse panels from someone on CC but do not know the year XJ that they came out of. Any way to tell? Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 25, 2019 Share Posted July 25, 2019 84-96 should all be the same. Link to comment Share on other sites More sharing options...
Manche757 Posted July 25, 2019 Author Share Posted July 25, 2019 7 minutes ago, Jeep Driver said: 84-96 should all be the same. Gotta love exact answers. Thanks Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted July 28, 2019 Share Posted July 28, 2019 Depends on what you are trying to do. Fuse boxes are probably 84-94-96ish. That if you just need the plastic holder and your wires and leads are ok.If you want to swap a new box in with the rest of the dash harness then you need to find the right year to match the bulk head plug in the fire wall.From what I can tell, this could be off a little if someone know better please correct it. 84-85 xj are unique for the old amc style bulk head.86 was the start of the renix era even though the 2.8 v6 was still an option.86-90 seem to have the same firewall bulk head plug. 91- through 94-95 I know look the same, far as the bulkhead plugs connecting engine harness to dash harness.1996 might be the same plug but they added OBD 2 to it, not sure about using those yearsSent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
