pingpong Posted September 13, 2007 Posted September 13, 2007 I know someone posted it a while back, and I searched and could not find it... but does some have a printable copy of the bolt hole locations on the front
LEAD_NOT_FOLLOW Posted September 14, 2007 Posted September 14, 2007 http://www.greatlakesxj.com/tech/bumper_mount.pdf
Rokhound Posted September 14, 2007 Posted September 14, 2007 if that is the same print that i used double check because mine were off
pingpong Posted September 14, 2007 Author Posted September 14, 2007 Thanks guys..... I knew one of you all had it. I just need something close so I can rough it out.... then I will make a set exact to the vehicle
mjeff87 Posted September 14, 2007 Posted September 14, 2007 Pat, I need a set of those for that Tomken bumper I have on the MJ. If you're fabricating, you can use my rig as a guinea pig ;) I already picked you up a box of 6013 rods.....I'll go get some more.... Jeff
pingpong Posted September 14, 2007 Author Posted September 14, 2007 Thanks jeff.. What size did you get? I need to go buy some 6x3/16 flat. There might be a small run of these available. I might be able to get them done professionally, or I might just make a few... not sure.. depends on what the quote is from the fab shop. I just have to make sure the drawings are right
mjeff87 Posted September 14, 2007 Posted September 14, 2007 1/8" There's a nice piece of 1/4" C channel sitting here at work, just rusting away outside the building. I'm working on the boss to let me take it away....it's about 8' long X at least 6" (or so, haven't measured it). I figure you could use it for something. Would make for one hell of a bumper :D edit: it's 1/8" not 1/4", 8" by about 8.5 feet long
87manche Posted September 14, 2007 Posted September 14, 2007 1/8" There's a nice piece of 1/4" C channel sitting here at work, just rusting away outside the building. I'm working on the boss to let me take it away....it's about 8' long X at least 6" (or so, haven't measured it). I figure you could use it for something. Would make for one hell of a bumper :D edit: it's 1/8" not 1/4", 8" by about 8.5 feet long meh, I thought the same thing, but my 1/4" 2x6 C is all bent up in the back. I even bent it up into the body under the tail lights.
pingpong Posted September 15, 2007 Author Posted September 15, 2007 YOu must not have gusseted it for abuse.... thats the key to nuilding with thinner metal
