mancheflo Posted May 22, 2019 Share Posted May 22, 2019 Any recommendations for a 2 inch lift or is there anyway to get that 2 inches of lift by any other way than buying a lift kit Link to comment Share on other sites More sharing options...
Pete M Posted May 22, 2019 Share Posted May 22, 2019 cheaper than 2" poly spacer pucks and the Chevy 2" drop shackles? Link to comment Share on other sites More sharing options...
mancheflo Posted May 22, 2019 Author Share Posted May 22, 2019 1 hour ago, Pete M said: cheaper than 2" poly spacer pucks and the Chevy 2" drop shackles? That sounds pretty cheap 😂 would I need new shocks and springs with that Link to comment Share on other sites More sharing options...
Pete M Posted May 22, 2019 Share Posted May 22, 2019 nope. the spacers go above your springs and the shackles replace what you have. any taller and you'd need to think about the other components, but the 1.75 to 2" spacer lift is small enough to retain the stock parts. Link to comment Share on other sites More sharing options...
Smokeyyank Posted May 22, 2019 Share Posted May 22, 2019 I run ACOS on mine. I did it to balance out the rack give you tons of versatility over spacers. Don't know how much I "lifted" it. Probably about 1.5". You can also run upcountry springs for a little boost. I have a little taller shocks but that was because I swapped them over from my XJ that was lifted Link to comment Share on other sites More sharing options...
mancheflo Posted May 22, 2019 Author Share Posted May 22, 2019 14 hours ago, Pete M said: nope. the spacers go above your springs and the shackles replace what you have. any taller and you'd need to think about the other components, but the 1.75 to 2" spacer lift is small enough to retain the stock parts. Thanks! I’ll have to look into that! Link to comment Share on other sites More sharing options...
