Blaine.D Posted May 17, 2019 Share Posted May 17, 2019 Took my truck out on a test drive today and discover the ebrake was rubbing on the driver side wheel. Does anyone have any suggestions on routing the cable and pictures of the cable to get it away from the wheel? Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 17, 2019 Share Posted May 17, 2019 Is it rubbing on the outer drum ring? I have the same issue and I’ve just did my best to force the cable back far enough to where the rubber hooks on that guide Link to comment Share on other sites More sharing options...
Blaine.D Posted May 17, 2019 Author Share Posted May 17, 2019 5 minutes ago, eaglescout526 said: Is it rubbing on the outer drum ring? I have the same issue and I’ve just did my best to force the cable back far enough to where the rubber hooks on that guide No the cable isn't touching the drum. It's touching the wheels. I forgot to mention the wheels are 16" oem wheels off of a Jeep Wrangler tj. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 17, 2019 Share Posted May 17, 2019 Long springs or tie wire. Link to comment Share on other sites More sharing options...
