Rough running 4.0
So for a few months now my MJ has been running rough once it idles for about a minute after start up. Gets worse as it heats up. I've checked everything. 02 sensor, CPS, TPS, MAP, IAT, CTS, cleaned throttle body (it's a bored out one. Clean as a whistle). I've tightened my intake bolts and plan to change my exhaust manifold and the gasket soon to rule out any possibility of a leak. I've deleted the EGR and the Jeep already had the Cat cut off (planning to redo the whole exhaust and add a cat again to regain the back pressure). I've refreshed grounds and indexed the distributor. Changed plugs/cap/wires/rotor within 5000 miles ago. Tested fuel pressure and the regulator and both check out as good.
Any idea where I should start next? It's frustrating me because I want to get it running perfectly before I continue doing other work to it.
18 hours ago, Ωhm said:
Did you check O2S heater circuit? Disconnect O2S. On the component side measure ohms between pins C229_A and C229_B. Should read ≈6Ω's.
My pins were not labeled but I tested the red and black wires and got exactly 6 OHMs. Is this test to be done with the engine hot, or cold?
Measurement should be taken at room temperature. 6 ohms prove good O2S heater.
12 minutes ago, Ωhm said:
With O2S disconnected. Measure C229_B(BLK) on the harness side for a path to ground (0 ohms).
With O2S disconnected and IGN SW in the ON position, measure C229_A(ORN) on the harness side for voltage (B+).
Do both of these test.
When testing the black wire it came back with .002 OHMs. Testing the orange wire for voltage with the key in the on position did not show any voltage unless the black terminal of my multimeter was grounded through the grey wire (c on the plug). It only showed 5 volts though. Even grounding the black terminal of the multimeter through the frame did not show a reading on the orange wire.
Need two (2) more voltage tests. Use the Diagnostic Connector (should have yellow covers on them). Ground DVOM at the battery terminal.
KEY ON
D2-4 & D2-9. Looking for B+ voltage.
I found this little bundle of poorly soldered orange wires wrapped in duct tape. Any idea what they are? Also found that the relay that Google said was the heater relay, was not actually the heater relay. Instead of being the first relay on the right, mine is the second relay from the left. The one I'm pointing at. The right 2 relays have 4 terminals in use and have 1 wire with 12v power with key OFF. The left 2 relays have 5 terminals in use and only have 12v if the key is in the ON position. The heater relay has a yellow wire (86) which has 12v power to it with the key ON. but upon back probing the relay with the key ON, the orange wire (87a) does not have power still. There is also 2 orange wires coming off of 87A. Any reason why? The fat orange one has got multiple breaks in the insulation. I'm thinking by the end of this I will have to replace a good section of it. The engine does NOT have to be running to have power to 87A, correct?
One (1) of those wires should go to the Fuel Pump Relay (C216_4(87)) or one of those wires should go to Diagnostic Connector D1_6?
You can slide the relay blocks back or forth to dislodge them and place them in any order you want. Makes me think somebody was doing something at one time.
Pin 86 is not tied to 87a. Yellow on pin 86 should be the Fuel Pump Relay.
Not sure about this one. If it the O2 Heater Relay, could be one wire for O2S Heater, other wire for D2-9.
If we're talking about the O2 Heater Relay, KEY ON works, relay needs to be installed. No need for engine to be running.
O2 Heater Relay pinout.
Pin 1 (30) Yellow
Pin 2 (85) Gray/Yellow
Pin 3 (87a) Orange
Pin 4 (87) Orange/Black
Pin 5 (86) Orange
02 Heater gets 12v power with key ON for about 3 seconds. After that it has no power unless you start the engine. The heater only has power while the fuel pump is priming with Key ON. Still having a rough idle. I'm starting to think maybe the 02 isn't a good brand? It doesn't have any markings on it but it is not the original 02 sensor.
Another question,
When indexing the distributor, with the #1 cyl at TDC, where do I need to set the rotor at? The write up says the trailing end, but in the picture on the write up it shows the tail end of the rotor covered by the #1 terminal.
Is it supposed to be like this IMG_20190524_172724.jpg.89e73d6eef317b68bf3249a9483b92a1.jpg
