Lee21490 Posted May 8, 2019 Posted May 8, 2019 Trying to find a tougher version of the Drivers side frame motor mount, Somehow mine snapped in half & Took part of the frame with it... Anyone know of any? My Google skills are failing me right now... https://parts.doverdodgeparts.com/a/Jeep_1995_Cherokee-SE-Sport-Utility-40L-Power-Tech-6-cylinder-MT-4WD/_51507_6400365/ENGINE--TRANS-MOUNTING-INLINE-6-CYLINDER/WB4067.html #3 on that diagram. Guess its a bracket out of a 95' cherokee Still can't find a heavier duty version of it.
Dzimm Posted May 8, 2019 Posted May 8, 2019 Brown Dog makes mounts that are very good quality and they also sell larger brackets with more attachment points.
Lee21490 Posted May 8, 2019 Author Posted May 8, 2019 1 hour ago, Dzimm said: Brown Dog makes mounts that are very good quality and they also sell larger brackets with more attachment points. I saw those, But those look like the motor side mounts.. And I need frame side.
Smokeyyank Posted May 8, 2019 Posted May 8, 2019 So you're saying you snapped the bracket at the unibody that actually attaches to it? I don't know of anyone that makes HD frame mounts. Only motor mounts and engine plates.
Lee21490 Posted May 8, 2019 Author Posted May 8, 2019 4 hours ago, Smokeyyank said: So you're saying you snapped the bracket at the unibody that actually attaches to it? I don't know of anyone that makes HD frame mounts. Only motor mounts and engine plates. Yea, the bracket. /e Turns out the frame/unibody isnt really that bad just a slight crack in one spot. Gonna weld it & replace the bracket with a stock one i guess, Since i havent found any heavy duty ones. Thanks.
Smokeyyank Posted May 9, 2019 Posted May 9, 2019 15 hours ago, Lee21490 said: Yea, the bracket. /e Turns out the frame/unibody isnt really that bad just a slight crack in one spot. Gonna weld it & replace the bracket with a stock one i guess, Since i havent found any heavy duty ones. Thanks. Gotcha, well if you are going to swap in some motor mounts I'd look at Stinkyfab.
