Jeep Driver Posted April 8, 2019 Share Posted April 8, 2019 I need extended rear stops, will the universals work? Will the XJ stops fit? Thanks. Link to comment Share on other sites More sharing options...
Pete M Posted April 8, 2019 Share Posted April 8, 2019 are your current ones intact? can you weld an extension in the form of a plate to the axle side of the equation? Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 8, 2019 Author Share Posted April 8, 2019 It's a matter of replacing with new and I might as well go extended. Link to comment Share on other sites More sharing options...
Eagle Posted April 8, 2019 Share Posted April 8, 2019 XJ and MJ bump stops are interchangeable, but the factory offered four different heights. Depending on model and options, an MJ could have any of the four: 5200 2382 ==> 74mm 5200 2381 ==> 90mm 5200 2393 ==> 104mm 5200 2078 ==> 117mm The XJ only used the 74mm or the 104mm Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 8, 2019 Author Share Posted April 8, 2019 1 hour ago, Eagle said: XJ and MJ bump stops are interchangeable, but the factory offered four different heights. Depending on model and options, an MJ could have any of the four: 5200 2382 ==> 74mm 5200 2381 ==> 90mm 5200 2393 ==> 104mm 5200 2078 ==> 117mm The XJ only used the 74mm or the 104mm Excellent! Thank you. Link to comment Share on other sites More sharing options...
