13 hours ago, Noah Hamilton said:
Looking at getting a lift for my Comanche, I want to put 37s under it,  what lift is best to get?
There's not really a "lift kit" for 37's unless you plan on just having a pavement princess. Get ready to fab and swap axles. You're venturing down the rabbit hole past 35's.
37''s involve far more than just a lift kit. You really need bigger axles from a full size truck, 1/2 ton or larger depending upon your intentions, not to mention piecing together all other parts needed and fabbing them to withstand the added forces involved with tires and axles that big and larger. Also not covered is the proper axle gearing needed for tires that large. It gets expensive real quick.
