2.5 v belt style harmonic balancer obsolete?
I have not done this myself but in my searches I found that the crankshaft snout is different, people mentioned needing to add a shim to get the crank pully to align with the rest of the components. Otherwise everything else can just be bolted on from the serpentine motor. IIRC there is a 3/8" difference between the serp and v groove crank pully.
hope that helps!
hope that helps!
The snout change came later, around '97 IIRC.
You can install an early serpentine balancer on a later snout but not a later balancer on an early snout...........no shim.
If your MJ has AC, the later AC compressor will not mate to your existing lines AND the later balancer will not go on the snout..........so.........for all practical purposes the later TJ/XJ MPI accessories are out of the question.
You'll need a complete accessory package/assembly from a '87-'90 XJ or MJ.
  • 2 years later...
Sorry to revive a 3 year old post but did anyone end up getting anywhere with this? I'm going the other direction with a conversion, using a 2.5 in a Willys CJ build and ive started converting over to a 3 point v belt setup but I'm stuck trying to find a balancer. Did anyone find out for sure if the GM balancer will fit dimensionally on the 2.5 snout? I'd gladly have one neutral balanced if it were that easy. Also would a V belt balancer from a 4.2 fit? Hesco sells one that doubles as a crank position sensor and that would be perfect for the MicroSquirt fueling setup ill be running for it. Thanks all :beerbang:
