Codybelec Posted January 11, 2019 Posted January 11, 2019 (edited) 3-1992 Comanche Elimantor Its a 4.0L 4x4 standard. I bought the jeep with a blown motor sitting on 31s. I'm swapping in a 97+ 4.0L and then I'm going to focus on body work and rust control and get the jeep back on the road as my daily driver while I continue to just wheel an XJ. The jeeps in pretty rough shape there's lots of rust here in Nova Scotia but over time it will all be gone over. I'm not sure of what transmissions in it, what axles or transfer case I just picked it up but I'll update once I check it over.—EDIT— Got the Jeep running it’s got a 2000 tj 4.0 and 6” long arms with Soa in the rear it runs and drives and Is going to get body work and paint by the end of the summer Edited May 21, 2019 by Codybelec Added a picture
JMO413 Posted May 25, 2019 Posted May 25, 2019 *C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT -SA Charcoal 123 Zone 23-Canada-Atlantic 1AB Canada Dealer Retail 25E Customer Preferred Package 25E 2TE Customer Preferred Package 2TE 3VR Customer Preferred Discount 4EA Sold Vehicle 4HC Special Scheduling Condition III 4UA SCA Tissue North America LLC ADA Light Group ADL Skid Plate Group APA Monotone Paint ARL 300 Premium Group BAP 75 Amp Alternator BCC Dual 730 Amp Maint Free Batteries BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JDC 200 KPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3L STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LAJ Headlamps On Warning Chimes LAP Shift Indicator Warning Lamp LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Door Armrest Storage Lamp LDA Underhood Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LMK Daytime Running Headlamps, High Beam MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHK Engine Block Heater PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8 QB8 MIDNIGHT BLUE MET CC SEC PNT - HB8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires TZA Goodyear Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAC Build To Canada Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Body Model JL62 Build date 3/26/92
Codybelec Posted May 26, 2019 Author Posted May 26, 2019 Someone else sent me the build sheet when I got it so cool to see there the same
jdog Posted January 31, 2021 Posted January 31, 2021 Selling Dealer: BRIDGEWATER DODGE CHRYSLER Bridgewater, NS (CAN)
