1988 4.0 BA 10/5 Clutch soft
Just bought a 1988 Comanche and one of the problems it had was that the clutch was super hard and would just stick all the way to the floor. I figured out the clutch master cylinder was stuck so I bought a new one and replaced it. Now i'm trying to bleed the system and the clutch is super soft and I guess I can't get all the air out of the system maybe. I noticed when I remove the pipe off of the slave cylinder and press the clutch theres not much pressure coming out of the lines. I can hold the pressure with my finger. With the master cylinder out it feels like it has decent pressure if I push the rod with my hand. Anyone had this problem and know whats wrong?
1 minute ago, Pete M said:
it is highly recommended as bubbles in the master are real hard to remove. :(
If I get some kind of vacuum pump bleeder kit would that work with the master already installed? I'm not to knowledgeable on bleeding clutch systems and don't know the process to bleed the master on a bench. I'm guessing I have to hook up some lines to it or something while pumping it?
