mbrady Posted December 25, 2018 Share Posted December 25, 2018 I just was able to get a hold of an 88' last month. Ive been pretty much going over the truck to get an idea of the initial work to be done. The truck came with a lift kit "installed". The lower control arms on the front end were not swapped over so the negative caster is obvious. I wanted to know if there was a reason someone wouldn't have done so if gone through the trouble of everything else? I believe its a 6" lift but would also be interested if someone could help me determine how to figure that out. Are there any references on the site I could use? Link to comment Share on other sites More sharing options...
Pete M Posted December 25, 2018 Share Posted December 25, 2018 why would someone skip an important part? cheapness or ignorance. pics would be helpful so we can see what you're dealing with. Link to comment Share on other sites More sharing options...
mbrady Posted December 25, 2018 Author Share Posted December 25, 2018 Will get some pics, hopefully tomorrow. I got the parts with the truck, just resting in the cab for now. Thanks for the reply and Merry Christmas. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 26, 2018 Share Posted December 26, 2018 Welcome mbrady. Go to www.cruiser54.com and complete tips 1 through 5 first chance you get. Link to comment Share on other sites More sharing options...
mbrady Posted December 27, 2018 Author Share Posted December 27, 2018 Thank you for the link. I had a couple work things come up and just delaying getting back to the truck. Hope to attach pictures soon. I also found another 88 that someone has given up on a rebuild. I was interested to have it for parts or maybe itll be better off than my own. Mine is a pioneer and his isnt. Are there some differences in models that i should be aware of before id picking up this other one? Link to comment Share on other sites More sharing options...
Pete M Posted December 28, 2018 Share Posted December 28, 2018 trim level mostly just means it has a few more things standard. but even then a base model could be ordered with all sorts of things that are standard on a higher level truck. Link to comment Share on other sites More sharing options...
mbrady Posted December 29, 2018 Author Share Posted December 29, 2018 here's a couple pictures. The bracket on the axle is due to be replaced but I'm not there just yet. Rusted pretty bad. Link to comment Share on other sites More sharing options...
mbrady Posted December 29, 2018 Author Share Posted December 29, 2018 Link to comment Share on other sites More sharing options...
mbrady Posted February 6, 2019 Author Share Posted February 6, 2019 Ive done some work to get this back to a 3" lift kit. I'm trying to find out long the sway bar links should be or a rough angle it makes with the sway bar. Any suggestions? Link to comment Share on other sites More sharing options...
