Cali Cruse Posted October 28, 2018 Share Posted October 28, 2018 From the pains of a malfunctioning blower motor and a non-working radio now being fixed, onto the next item, that is driver's side window trimming. With the rain, I've been noticing a fair amount of moisture getting into the cabin. Is this something as simple as going to a windshield/window repair place, going to Ziebart, and getting the rubber trimming put on, or is it something more involved that requires Comanche specific trimming? Thanks. Link to comment Share on other sites More sharing options...
Blaine.D Posted October 30, 2018 Share Posted October 30, 2018 On 10/28/2018 at 12:59 PM, Cali Cruse said: From the pains of a malfunctioning blower motor and a non-working radio now being fixed, onto the next item, that is driver's side window trimming. With the rain, I've been noticing a fair amount of moisture getting into the cabin. Is this something as simple as going to a windshield/window repair place, going to Ziebart, and getting the rubber trimming put on, or is it something more involved that requires Comanche specific trimming? Thanks. Sounds like to me the rubber on the window is old and not able to flex. My suggestion is to buy a door weatherstripping kit that includes all the pieces for both doors, prp makes one or buy the pieces you need Crown Automotive sells them by the piece. Link to comment Share on other sites More sharing options...
Pete M Posted October 31, 2018 Share Posted October 31, 2018 are you talking about the door seals? late model XJ seals are a bit thicker and go right on. Link to comment Share on other sites More sharing options...
Cali Cruse Posted November 2, 2018 Author Share Posted November 2, 2018 On 10/30/2018 at 10:39 PM, Pete M said: are you talking about the door seals? late model XJ seals are a bit thicker and go right on. That's exactly it! Is it an online purchase or does any parts store carry it? That's why my blower motor fuse shorted again, every time it rains moisture has been getting in and shorting out the fuse. Literally, a kingdom for a door seal, is how I'm feeling. Link to comment Share on other sites More sharing options...
Pete M Posted November 2, 2018 Share Posted November 2, 2018 I imagine they are available in both places but I don't know for sure. I got my set from the junkyard Link to comment Share on other sites More sharing options...
Cali Cruse Posted November 7, 2018 Author Share Posted November 7, 2018 So I tracked down the leak, it is coming from the windshield as I suspected above. Since the windshield is cracked, I'm going to have it replaced also, in addition to the rubber seal (weatherstripping) all the way around. Would I still need the thin metal trim pieces all the way around the windshield, or are they purely cosmetic and and can be discarded? Link to comment Share on other sites More sharing options...
Pete M Posted November 8, 2018 Share Posted November 8, 2018 I believe the 97+ rubber windshield gasket replaces those trim bits. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 8, 2018 Share Posted November 8, 2018 6 hours ago, Cali Cruse said: So I tracked down the leak, it is coming from the windshield as I suspected above. Since the windshield is cracked, I'm going to have it replaced also, in addition to the rubber seal (weatherstripping) all the way around. Would I still need the thin metal trim pieces all the way around the windshield, or are they purely cosmetic and and can be discarded? If you want to keep it original (I did) and the windshield trim is in good shape (mine was), the installer can reinstall the trim using the earlier gasket. If not, ask the installer to use the 97+ windshield gasket. Link to comment Share on other sites More sharing options...
