mark 39 Posted September 26, 2018 Share Posted September 26, 2018 I need to put in a new rad and decided on FFD aluminum two row. I can't tell from the web site pictures or description if there is provision for stock fan switch sensor in left tank. Plan on using stock mechanical and aux. electric fan . Information on this or any other tips or warnings will be appreciated. Thanks in advance. Mark Link to comment Share on other sites More sharing options...
bad_idea Posted September 26, 2018 Share Posted September 26, 2018 Typically the all aluminum aftermarket radiators are cheaply made in China. Typically. It's usually the welds that are kind of crappy. If you can TIG aluminum or know someone that can, then they are a good deal. I have no experience with that brand, or any other. Just passing along what I have read online and word of mouth from others. Take my input for what you paid for it. Do you have a link? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 26, 2018 Share Posted September 26, 2018 The FFD radiator is not made in China. And it does have the bung with the correct thread for the Renix temp sensor, circled below. I have one and it works well cooling the stroker. Link to comment Share on other sites More sharing options...
mark 39 Posted September 26, 2018 Author Share Posted September 26, 2018 Thanks Don. I have another question you can probably answer . Do factory trans cooler lines fit or do I need to adapt with hose? I have the factory tow package cooler so do I even need to go through the radiator cooler? It does get below zero here in winter ; perhaps warming trans fluid wouldn't hurt? Any mounting problems or just plug and play? Thanks again . Mark Link to comment Share on other sites More sharing options...
bad_idea Posted September 26, 2018 Share Posted September 26, 2018 You have perked my interest. Does anyone have a link to it? Link to comment Share on other sites More sharing options...
mark 39 Posted September 26, 2018 Author Share Posted September 26, 2018 ^^ ffdynamics.com Sorry I'm not confuser competent so couldn't give you a direct link. I should learn a bit more , I guess. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 27, 2018 Share Posted September 27, 2018 18 minutes ago, mark 39 said: Thanks Don. I have another question you can probably answer . Do factory trans cooler lines fit or do I need to adapt with hose? I have the factory tow package cooler so do I even need to go through the radiator cooler? It does get below zero here in winter ; perhaps warming trans fluid wouldn't hurt? Any mounting problems or just plug and play? Thanks again . Mark Yes, the factory tranny cooling line quick-connectors do fit the FFD radiator cooler elbows. The radiator tranny cooler isn't much - it's tiny. I also have the factory towing package cooler and plumbed in a larger aftermarket cooler (Tru-Cool p/n LPD49201) in series with it for the AW4 and abandoned the radiator cooler. The two aux coolers work well keeping the AW4 happy and since there is no more hot tranny fluid running through the radiator, the radiator stays cooler for the engine. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 27, 2018 Share Posted September 27, 2018 43 minutes ago, bad_idea said: You have perked my interest. Does anyone have a link to it? https://ffdynamics.com/products/jeep-cherokee-aluminum-radiator Link to comment Share on other sites More sharing options...
bad_idea Posted September 28, 2018 Share Posted September 28, 2018 Their site doesn't mention country of origin. In my experience when a manufacturer doesn't mention COO, it's usually China. I'm sure it's a quality product, but usually USA manufacturers are proud to mention it. Link to comment Share on other sites More sharing options...
