scottie005 Posted August 26, 2018 Share Posted August 26, 2018 Would it be easier to swap a 97 dash into the HO comanches in the early 90s vs the renix Comanches as far as the wiring harness would go? Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 26, 2018 Share Posted August 26, 2018 If you're swapping to the '97 you are swapping everything, everything means everything, so it really doesn't matter. Link to comment Share on other sites More sharing options...
Dzimm Posted August 27, 2018 Share Posted August 27, 2018 No difference I'm aware of, same amount of work. You don't plan on ONLY swapping the dash do you? Swap it ALL or nothing. Link to comment Share on other sites More sharing options...
scottie005 Posted August 27, 2018 Author Share Posted August 27, 2018 I’m still looking for a Comanche but I plan on swapping it all Link to comment Share on other sites More sharing options...
Dzimm Posted August 27, 2018 Share Posted August 27, 2018 21 hours ago, scottie005 said: I’m still looking for a Comanche but I plan on swapping it all In that case yeah, it doesn't matter. Everything is coming out and coming from the 97+ XJ. You will have to fab all new mounts for the dash but the wiring harness is encorporated into the dash, you'll just plug it in to the other wiring harnesses from the XJ. Check out some of the 97+ build threads to see what everyone has done. Link to comment Share on other sites More sharing options...
