scottie005
Everything posted by scottie005
  1. Hey uh, long time no see. I recently got a second wind to start chipping away at stuff. I just finished swapping in a correct crossmember for the AX-15. Got it off ebay, took it to work, sand blasted it and painted it. I've also started preping for floorboard work again [I'm dreading this process so much, but I need to conquer this hill]
  2. I’ll post some pictures tomorrow morning!
  3. So trying to get my dash back together and its a mess, I've got boxes and wiring harness hanging everywhere and I have no idea where it mounts, do any of you know of a write up that can help get me on track? I'm trying to clean my comanche up after sitting for almost a year
  4. I got quoted 56 a month for liability
  5. She’s back home from the hanger, finished putting the AX-15 in and drive it home. It drives and shift so much better. 11/10 upgrade would do again
  6. Flipping 180 got it close enough! Thank you!
  7. I’ve got my AX-15 in my Comanche but it isn’t lining up with the BA/10 hole in the floorboard, am I missing something here?
  8. Well I’ve begun the process of swapping the transmissions, in that time frame I’ve also cut out and fitted the driver side floorboard, currently in the process of the passenger side!
  9. In the middle of the photo where the two braces meet there are small black dots from the pitting after I’ve sandblasted it. Is that clean enough to paint over? Or is it still going to rust?
  10. End of the week update, I didn't really get time to work on the comanche throughout the week, I did get to fiddle with it today. I've currently got the steering column apart to check those reverse torx bit bolts that holds the steering column and wheel tight. I want to make sure mine are tight and I want to lock-tite them as well, I have to wait for some tools to show up Tuesday to finish the job. Did some glancing over the vacuum lines because the comanche's idle is constantly dipping up and down. it seems that a lot of the tubing is secured into their receptacles via electrical tape, just another thing to add to the list...oh and of course all the wiring looks like a rats nest with random plugs just flopping about I also disconnected the firewall fuse box to try and start cleaning up the rust where fluid dripped through, I got a little bit done before I realized this might warrant taking the dash out , so I reconnected the firewall plug and snugged it down for a future day. Finding more rust always puts a damper on the mood, but on the bright side I did score an AX-15 for 150 bucks! the tail housing will have to be re-clocked but no big deal. The 3 top things for me right now are get the floorboards fixed, get her steering straight, and swap that transmission in.
  11. The pictures would be nice!
  12. Also the guy I bought the transmission from doesn’t know what it came out of, so it’s probably a large possibility it’s out of a wrangler
  13. I’ve been using this write up as my basis for the swap
  14. Ooo my apologies! I didn’t see your first reply. I’ll give it a shot(s)! thank you (:
  15. Thank you! I’ve got a 231J that I’ll mount to it, and advance adapters makes a mounting plate that allows you to use the BA10 crossmember with the AX15 transmission
  16. Every time I start it, the start gets progressively longer
  17. I just picked up an AX-15 to swap into my comanche and get rid of that BA-10, its a transmission and the bellhousing, it has the clutch fork/bearing but it doesn't have a slave cylinder. Would I just need this kit from advanced adapters? or am I missing some things.
  18. https://imgur.com/a7spcED hopefully it will work through imgur, also make sure the audio is on, it defaults to off for me
  19. Recently purchased an MJ, I’ve noticed that it takes a few cranks to get it started and then it revs real high on its own once it’s running. I’ve heard of Renixs having long cranks but something seems off to me *side note: the tac doesn’t work in case you notice in the video* IMG_5554.MOV
  20. I might change out the seats to a nicer XJ pair or ZJ. Center console out of an XJ and I’ve got a gauge cluster with a tach I want to also swap. Find some carpet for the time being after I clean the floorboards
  21. Guy told me that someone lifted the front end 3" but not the back, ultimately I'd like to turn it into a long distance camping/trips/overlanding rig. Eventually 97 swap, either an AX-15 or NSG370, swap the dana 35. I have a Chrysler 8.25 but I might go dana hunting instead. She's got a ways to go but I have to start somewhere
  22. Hello all! Its been two days since bringing home my comanche, might as well start posting about it! I picked up a 1988 Jeep comanche Pioneer, 4.0, Peugeot BA10/5 5-speed , 4x4. Truck originally came from Texas and was hauled up to Ohio by its previous owner, it has switch hands to me and still lives in Ohio. The previous owner also posted the vin number in the registry. Good news is that the cab corners and the rockers are rust free [at least on the outside] bad news is that the floor boards are rusty [what's new] The boards are at least solid for the most part. The truck came with a bunch of extra interior parts that I'll be selling.
  23. Here’s a list of what he’s done 180k miles Valve cover gasket New vacuum line assembly Power steering pump. Alternator Front calipers Fan shroud Closer to open coolant system Oil pan gasket Rear main Headlight wiring upgrade Fixed grounding issues New headlights Front grill Idle air control valve Radiator & heater hoses Listed for $3k
