MeanLemons Posted August 9, 2018 Posted August 9, 2018 Is there any difference in between 87+90 & 91-96 clutch pedal assemblies?
cruiser54 Posted August 10, 2018 Posted August 10, 2018 You mean brake and clutch pedal assemblies? Yes. 91 and later have a provision for a better brake light switch and the 95 to 96 booster swap.
MeanLemons Posted August 10, 2018 Author Posted August 10, 2018 Indeed. They look physically the same (the stamped steel part) the 91+ have a brake switch in a different location and has 6 wires. Which two are for brake lights? renix uses only 2 wire and is located on the pedal arm itself.
