Project Dirty Deeds: 4.0 SUPERCHARGED
2015: So I had a 96 XJ sport that had rusted out and the engine blew on me, it had a salvage title so it wasn't worth fixing but i just re built the AW4. So I went a searching for a MJ on craigslist to do a 4x4 swap and found one in Houston. The guy wanted $1200 for it but I talked talked him into trading 2 guns for it. I loaded up a car dolly and went to get it.
943990_159881461067100_89547833933606965
It was a 2wd 5sp so i had a bit of custom work to do
29598185_723090711412836_634098357597703
29683109_723090794746161_660459000256452
29570733_723090871412820_519029378322081
29570450_723091084746132_199338360681326
17022479_485994465122463_906989227990920
with everything installed i had one big problem... my MJ was a 87 and couldnt wire the TCM so i had to figure something out. Ra-Design makes a winter shifter to manually control the AW4 so i grabbed one!
29789889_723091148079459_608317484071646
with that out out of the way new gauges were next. i decided to go full race digital
38767194_829973360724570_606260957684957
32582034_752147598507147_167047163507480
32658091_752147741840466_123048114931944
next paint
17800428_513287679059808_178266727141918
17862805_513389765716266_862506155406904
17800373_513503322371577_819981206836296
18157898_527934757595100_260343670825804
next i wasnt sure what i wanted to do... so i said screw it ima put a blower on it! i bought a eaton m90 from a friend of mine and started planning
18447364_537545016634074_273472086593741
18556355_536959246692651_384027665674364
19224762_560145771040665_183215454906891
19274976_563696647352244_457373158861239
well thanks to Hurricane Harvey it got put on hold for a bit. once i started again i booked
22279505_624782607910314_473015601510046
i came up with a better mount and got the right belt
http://<img src="https://scontent-dfw5-2.xx.fbcdn.net/v/t1.0-9/32253761_748943095494264_3802156464919805952_n.jpg?_nc_cat=0&amp;oh=1b63eb27295073a6bf2bac435754b877&amp;oe=5BFF3614" alt="No automatic alt text available."/>
32336752_750129005375673_300819282637566
33676444_758704537851453_237387543721122
33757633_758704697851437_207868970082605
34139979_762307154157858_142507553899675
34199478_762307757491131_622809394520994
34198876_762309444157629_646623934192340
I got a special fuel and timing controller installed so i can tune it a little
29570289_766627130392527_603101230990675
and fixed a few minor plumbing problems leading me to now
36589831_790433914678515_821563622803741
https://youtu.be/GCDQeieLepk
https://www.facebook.com/100011357421019/videos/778488635873043/
