Renegade Posted August 21, 2007 Share Posted August 21, 2007 Putting a 4.5" lift on my '89. I got ahead of myself & pulled the end links off the swaybar before remembering the kit has drop brackets to lower the whole assembly. This turned out to be a good mistake since the links are rusted about halfway through where they bolt to the swaybar. I would rather leave the bar mounted where it is & get some longer endlinks. I don't need disco's since it is 2wd & won't go offroad. Anybody make what I want or do I have to use the drop brackets? Link to comment Share on other sites More sharing options...
lower jeep Posted August 21, 2007 Share Posted August 21, 2007 i think that quadratek make them i think Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 21, 2007 Share Posted August 21, 2007 Putting a 4.5" lift on my '89. I got ahead of myself & pulled the end links off the swaybar before remembering the kit has drop brackets to lower the whole assembly. This turned out to be a good mistake since the links are rusted about halfway through where they bolt to the swaybar. I would rather leave the bar mounted where it is & get some longer endlinks. I don't need disco's since it is 2wd & won't go offroad. Anybody make what I want or do I have to use the drop brackets? If you pick up 1992 or newer Jeep XJ or MJ sway bar links, they are about 1-1/2" longer than the ones you had on your 89. These were long enough for mine w. a 3" lift, and can be had at AutismZone, Advance, or NAPA. If these are not long enough to keep the bar ends from hitting your coil springs, check out Gojeep's page here to lengthen them: http://gojeep.willyshotrod.com/HowtoSwaybarlinks.htm Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 22, 2007 Share Posted August 22, 2007 I built mine with an extension and some washers. didn't take long and works nice. Link to comment Share on other sites More sharing options...
Renegade Posted August 22, 2007 Author Share Posted August 22, 2007 Found what I needed. Thanks! Link to comment Share on other sites More sharing options...
