Pannicthrottle Posted May 12, 2018 Share Posted May 12, 2018 Any problem welding axle perch with 121volt welder. Any tips on this axle swap would be greatly appreciated. Link to comment Share on other sites More sharing options...
kryptronic Posted May 12, 2018 Share Posted May 12, 2018 I'd take it to somebody with a bigger welder. I seriously doubt you can get the penetration you need with low amps. Link to comment Share on other sites More sharing options...
PCO6 Posted May 12, 2018 Share Posted May 12, 2018 I agree. You could cut the old ones off, grind down the cuts, tack on your new perches and take it all in for final welding. It would save you a few bucks and it would make sure you get things lined up the way you want it. Also ... that axle needs to go in at the other end of your Jeep! Link to comment Share on other sites More sharing options...
Pannicthrottle Posted May 12, 2018 Author Share Posted May 12, 2018 Thank you both I was hoping to here I could get it set up tacked and clamped then limp it 20mins to a guy that can weld it. No one thinks revers steering would be cool lol thanks againSent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
