agamble Posted May 6, 2018 Share Posted May 6, 2018 I am attempting to wire up power windows in the Comanche. Nothing is hardwired yet, as I am trouble shooting. I've tapped into the fuse box, crudely for now, which runs through a fuse. It then splits into two. I have one line powering the master control switch on the driver side, the other goes to the passenger side control switch. As it stands I can get the master control switch on the drivers side to open and close the drivers side window. Then I am able to get the passenger side control switch to window to open and close the passenger window. The problem is when I try connected the master control switch for the passenger window in. To tie them, the master control switch and the power window motor, together I have taken a third wire, which I tied into the master control switch passenger window wires, then ran that over to the passenger motor wires. When I attempt to tie the master control switch in to be able to also control the passenger window I keep blowing the fuse. If it doesn't blow immediately upon connecting the wires, as soon as I flick the master control switch for the passenger window it will blow the fuse. What am I doing in correctly? Link to comment Share on other sites More sharing options...
Eagle Posted May 7, 2018 Share Posted May 7, 2018 Are you working from a wiring diagram, or are you guessing? Link to comment Share on other sites More sharing options...
agamble Posted May 7, 2018 Author Share Posted May 7, 2018 Guessing. I was being lazy and didn't want to take the time to find or draw. I have since seen the error in my ways and took the time to draw out a wiring diagram and found the solution to the problem. Below is the diagram I drew for reference: The problem was I was putting power to the negative side of the switch, which in turn was causing the fuse to short out. The solution was I need to add a fourth wire. One for power, one for ground, one to connect the positive of the passenger side motor, and a separate for the negative side of the motor. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 7, 2018 Share Posted May 7, 2018 Link to comment Share on other sites More sharing options...
87MJTIM Posted May 7, 2018 Share Posted May 7, 2018 HOrnbrod, where does the passenger door switch ground? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 7, 2018 Share Posted May 7, 2018 3 minutes ago, 87MJTIM said: HOrnbrod, where does the passenger door switch ground? BLK cross-body wire Link to comment Share on other sites More sharing options...
87MJTIM Posted May 7, 2018 Share Posted May 7, 2018 Not shown in diagram Link to comment Share on other sites More sharing options...
