NCardwell Posted March 8, 2018 Share Posted March 8, 2018 Just noticed this today, but every time I turn, even when I’m not moving, I hear a distinct poping coming from under my butt. It kind of sounds rubbery when it pops too. Could it be bad bushings somewhere? Or I’ve seen videos on loose track bars, but the sound is coming from directly under me, or at least I think it’s where it’s coming from. Any help is appreciated. Link to comment Share on other sites More sharing options...
Dzimm Posted March 8, 2018 Share Posted March 8, 2018 Check your trackbar bolts on the frame behind your driver's front wheel. Also check your sway bar, sway bar bushings, and sway bar end links. Link to comment Share on other sites More sharing options...
Pete M Posted March 8, 2018 Share Posted March 8, 2018 should be easy enough to locate if you listen underneath while someone else turns the wheel. track bar is very common, but also control arm bushings and, well, pretty much anything underneath. Link to comment Share on other sites More sharing options...
