No brake lights
did this come on suddenly?  any trailer light wire harness integrated out back?
check the ground located inside the dr side taillight.  double check that all your bulbs are correct and the sockets are in good shape.  after that I would check the harness connector located behind the drivers side rear tire underneath the truck.  I had corrosion inside that killed the brake lights / turn signals.
No idea just bought the truck. Had been eaten alive on the wiring. Ground wasn't great so I redid it and it's very good now still nothing out back all bulbs are good etc. It does have a 4 pin trailer hook up integrated somehow. My fuel pump isn't coming on as well just fyi Incase it's related.
2 hours ago, Cmorris24 said:
No idea just bought the truck. Had been eaten alive on the wiring. Ground wasn't great so I redid it and it's very good now still nothing..
Which ground wasn't great? The one behind the left tail lamp? That's where everything electrical out back grounds.
Ok pulled fuel pump it's clearly bad lol and the lights all work etc not getting power to the harness but found a be one area so I'll pull the tank and fix it next hope to have it running soon. It's an 87 chief power windows & locks, bucket seat 4wd 4.0 already has ax15/np231 swap and only 105,000 miles. Paid 400$ clean body and title
You don’t need to drop the tank to change the fuel pump.  Make sure the fuel level is below the pump mounting, drop the driveshaft (to get more room to work), then remove the pump/sending unit by removing the lock ring.  When you remove the lines push a bolt into it and tighten the hose clamps to stop leakage.  Get a new lock ring and gasket when you re-install the pump/sending unit.
This is much easier than dropping the tank, unless you need to change the vent fittings or clean the tank.
Pulled the pump with the tank in but found frayed wire above it I need to get to and the tank is a wreck judging by the pump. Ethanol looks to have taken it's course after 5 years silly me for having faith it's not designed that way. So gotta drop it now but thank you for the tips this seems to be a great forum! I read more than I post so thanks for not flaming on ant dumb questions I try not to post them haha
