4x4 swap question
If you have cruise control, isn't your cable in two parts? The long (lower) cable runs from the transfer case through the firewall to the speed sensor module, then there should be a short cable from that to the speedometer head.
I @$$-U-Me he has the sensor and the short cable.
The Napa cables will screw on to the sensor, but not the speedo cluster.
