SledNeck91604 Posted January 14, 2018 Posted January 14, 2018 With a little bit of poking around I found the correct sockets for OEM bumpers. Dorman: 85880 BWD: PT152 Sent from my SM-G930V using Tapatalk
SledNeck91604 Posted January 14, 2018 Author Posted January 14, 2018 LED lamps do a great job overcoming the hazy old housings! Sent from my SM-G930V using Tapatalk
Keyav8r Posted January 14, 2018 Posted January 14, 2018 Which leds did you use (brand, PN, supplier)?
SledNeck91604 Posted January 14, 2018 Author Posted January 14, 2018 Which leds did you use (brand, PN, supplier)? They are just a standard 194 dual pack from the rack at O'Reilly's Auto. I'll get the info for you when I get back home. Sent from my SM-G930V using Tapatalk
Keyav8r Posted January 14, 2018 Posted January 14, 2018 SledNeck - My bad! You were referring to the license plate lights. I was thinking tail lights. I’ve opened up a driver side and a passenger side tail light housing, cleaned up the internal part and sprayed them with chrome paint. My plan is to use led bulbs for tails, turns and brakes as well as back-up lamps in hopes I’ll have a lot more light in the rear. Will do the license plate lights also. Don - Thanks for the list. Did you use SuperBright leds?
HOrnbrod Posted January 14, 2018 Posted January 14, 2018 7 minutes ago, Keyav8r said: Don - Thanks for the list. Did you use SuperBright leds? Si.
SledNeck91604 Posted January 14, 2018 Author Posted January 14, 2018 I used these for plate lamps. I'm happy with them! Hopefully they last quite a while for the price.. I'll be upgrading to LED when I have problems with incandescent lamps.. Only downside, my tail lamps are severely lacking now..Sent from my SM-G930V using Tapatalk
91Pioneer Posted January 25, 2020 Posted January 25, 2020 On 1/14/2018 at 7:23 AM, SledNeck91604 said: ...I found the correct sockets for OEM bumpers. Dorman: 85880 BWD: PT152 Thanks for the info, I recently picked up Comanche #4 and it’s missing these sockets.
