TheBandit Posted December 29, 2017 Share Posted December 29, 2017 Thanks to the advice in my no start thread, I have a Comanche that's running again! Now, I decided to tackle the turn signal issue. I don't have any brake lights, but the running lights work. I also don't have turn signals. When I flip the lever I don't have anything pop up on the dash- there is no annoying turn signal clicking or anything of that nature. What do you think could be the cause of this, or what should I do to test other possibilities? Also, I noticed that when I drive, the thermostat gauge is illuminated red, but the truck is not over heating. It has been around 3 or 4 degrees F around these parts lately and I'm curious if that's causing the recent flare. Link to comment Share on other sites More sharing options...
Pete M Posted December 29, 2017 Share Posted December 29, 2017 does anything work when you turn on the hazards? what do you mean by "illuminated red" Link to comment Share on other sites More sharing options...
TheBandit Posted December 29, 2017 Author Share Posted December 29, 2017 5 minutes ago, Pete M said: does anything work when you turn on the hazards? what do you mean by "illuminated red" Pete, the hazards do in fact work. As for the red, my dash doesn't have needles that point to anything it just shows the temperature symbol and behind it is a red light on the gauge Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 29, 2017 Share Posted December 29, 2017 What are you driving?? Link to comment Share on other sites More sharing options...
Pete M Posted December 29, 2017 Share Posted December 29, 2017 try swapping the hazard pot with the turn signal pot. check for power coming out of the brake switch. Link to comment Share on other sites More sharing options...
TheBandit Posted December 29, 2017 Author Share Posted December 29, 2017 29 minutes ago, HOrnbrod said: What are you driving?? It's a 1988 Comanche-should have specified Link to comment Share on other sites More sharing options...
TheBandit Posted December 29, 2017 Author Share Posted December 29, 2017 1 minute ago, Pete M said: try swapping the hazard pot with the turn signal pot. check for power coming out of the brake switch. Are those in the fuse box? Or do they hide under the dash Link to comment Share on other sites More sharing options...
Pete M Posted December 29, 2017 Share Posted December 29, 2017 in the fuse box. Link to comment Share on other sites More sharing options...
Jargon Posted December 30, 2017 Share Posted December 30, 2017 I just had an issue with the turn signals not blinking - the lights would turn on but not blink, both on the dash and outside. Hazards worked fine. Ended up replacing the relay to fix. You could swap the hazard relay with the blinker relay for troubleshooting. Link to comment Share on other sites More sharing options...
phatton Posted January 3, 2018 Share Posted January 3, 2018 While your at the fuse box check the 10 AMP fuse which controls the turn signals and backup lights. Link to comment Share on other sites More sharing options...
