Sunvisors swap
Hello to you all, I am in need of some advice regarding the Comanche sunvisors, I am aware there are two lenghts of them and I wonder if anyone has changed long for short ones or short for long ones and the technical issues that may arise in doing so, I think that the retaining clips bolt on differently in each case but don't know if the sunvisor itself will be interchangeable
Am I wrong or the long ones can be found in older MJ and XJ's and the short ones in newer models?
Currently my 90 Comanche has the short ones installed but I found a nice pair of the long ones that I want to know if it is worth the effort to get and install, thanks in advance...
Best Regards
They both attach in the same location with the same three screws. The long ones have a plastic center plate that the clips screw through into plastic inserts in the sheet metal. The headliner also has a cut out in it where the plate attaches, not sure if it's there for the short ones.
