Swampy
Hey guys. Been looking at tires recently. I wanted to get a set of 33x12.5x17 or 305/70r17. I know according to manufactures they should be close to there actual specs at max psi but we all know they mostly run a tad smaller.
My question is if I am looking for a set of 33-34" tires that are as close to that measurement, should I run a bigger size (for example a 35x12.5x17 bfg km2 because it'll actually be a 33) or should I just stick with the sidewall number (33x12, 285/70, 305/70 etc.)?
They are all different, i.e. some 33" manufacturer's tires are taller than 33", some are under. Decide on which tire you want, go to TireRack.com, search for that tire, then look at the specs. One of the entries will be the actual diameter of the tire.
http://www.kanatitires.com/products/truck-tires/mud-hog/#.Wil-yeQm7cs
Part #
Tire Size Load Range Tread Depth OD SW Rim Width Weight PSI Load Index Speed Max Load
L1726570E-252 LT265/70R17 10PR 18 31.9 10.7 on 8 7-8.5 54.1 80 121/118 Q 3195/2910
L1728570E-252 LT285/70R17 10PR 19 33 11.5 on 8.5 7.5-9 61.4 75 123/120 Q 3465/3120
L1733125E-252 33X12.50R17LT 10PR 20 32.8 12.5 on 10 8.5-11 59 65 120 Q 3085
On ‎12‎/‎7‎/‎2017 at 7:32 PM, Jeep Driver said:
What's your objective? Width or height or both?
Mostly height. Looking for a 33-34" tire. But would like a nice ratio of width and height. I like the kanati's
