NJ in the MJ Posted October 21, 2017 Share Posted October 21, 2017 1990 Jeep Comanche Pioneer 4.0, ax15, Dana 44 rear, 2wd, Long Wheelbase, Metric Ton Package Built: 11-89 Still on the road in eastern Missouri. 196,xxx mi. P.o. installed 4 in. lift, Dana 30, 98+ doors, console, and bucket seats. Also added 17" JK wheels/adapters and painted black, originally white. I blew the spiders in 44, installed Torsen diff. I did 4 hole injectors, engine mounts, and put relays on headlights. Also added adjustable uppers, lowers, track bar, and sway disconnect. Changed oil filter adapter to newer style, run oversized filters. Installed a pcv valve and reran hoses to stop oil leaks. Changed almost all bushings and joints, shocks, rear bearings, and installed longer front brake lines. Did rear main seal and cleaned tons of crap outa pickup. Runs beautifully. Link to comment Share on other sites More sharing options...
JMO413 Posted May 25, 2019 Share Posted May 25, 2019 *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 4AF American Coin Merchandising 5KN Metro Cars of Detroit ALN Body Color Bumper Group APA Monotone Paint ARL 300 Premium Group BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HW1 JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKE LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAE California Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1B GVW/Payload Rating Z57 Left Front Spring Group Vii Z76 Right Front Spring Group VI Body Model TL62 Build Date 11/8/89 Link to comment Share on other sites More sharing options...
jdog Posted February 10, 2021 Share Posted February 10, 2021 Selling Dealer: STAR CHRYSLER JEEP Glendale, CA Link to comment Share on other sites More sharing options...
