NJ in the MJ
NJ in the MJ's Achievements
  1. 1990 Jeep Comanche Pioneer 4.0, ax15, Dana 44 rear, 2wd, Long Wheelbase, Metric Ton Package Built: 11-89 Still on the road in eastern Missouri. 196,xxx mi. P.o. installed 4 in. lift, Dana 30, 98+ doors, console, and bucket seats. Also added 17" JK wheels/adapters and painted black, originally white. I blew the spiders in 44, installed Torsen diff. I did 4 hole injectors, engine mounts, and put relays on headlights. Also added adjustable uppers, lowers, track bar, and sway disconnect. Changed oil filter adapter to newer style, run oversized filters. Installed a pcv valve and reran hoses to stop oil leaks. Changed almost all bushings and joints, shocks, rear bearings, and installed longer front brake lines. Did rear main seal and cleaned tons of crap outa pickup. Runs beautifully.
