I am attempting to swap doors from 200 XJ (Power everything) onto my 91 MJ.
I see that the hinges look entirely different but it does look like the hinges from the 91 MJ will bolt on to the 2000 XJ doors. I that correct? Is that the way to proceed?
I also see that the weatherstripping is very different between the 2000 XJ donor and my 91 MJ. How do I address this problem? In order to use the weatherstripping from the 2000 XJ, it looks like I would have to also use the associated trim pieces, which I can't see working in the MJ. How do I address this?
Thanks
Unbolt the existing hinge from the door and bolt it up to the new door.
The weatherstripping will swap over without having to change the trim.  The trim won't sit perfectly along the bottom of the door but it also doesn't look out of place.
  • 1 month later...
57 minutes ago, pfloyd32086 said:
By the way donor doors are manual everything.
Should bolt right up no issue.
