ComancheCrusher9800 Posted August 1, 2017 Share Posted August 1, 2017 Okay so my old engine died so I rebuild the one out of my older mj. I went to put it in and hooked everything back up and it won't start. It'll sit there and crank. I didn't aline the hormonic balancer the right way with the marker but I don't think that should matter because the dots were aligned on the timing sprockets. And I do have gas and it will turn over so I know it's something with the spark. But to do with that. I am getting spark from the coil but not from the distributor. The spark has gone back the distributor ( I know because it got me when in did) but I couldn't see the spark jumping every time with every plug wire and I don't see why. Can someone please help me with this Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 1, 2017 Share Posted August 1, 2017 Your dist is out of phase. Go to TDC...........that mark you ignored.........on the compression stroke and index your dist. Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted August 1, 2017 Author Share Posted August 1, 2017 Say that one more time without all of the dots Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
Big Dan Posted August 1, 2017 Share Posted August 1, 2017 He's saying to set the #1 cylinder to top dead center on the compression stroke. And, index your distributor. Your distributor timing is out of whack. Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted August 1, 2017 Author Share Posted August 1, 2017 I get a spark in #1 cylinder only. None of the other cylinders have spark Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted August 1, 2017 Author Share Posted August 1, 2017 And I did that Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted August 1, 2017 Author Share Posted August 1, 2017 The camshaft sprocket came off. We put it back on. Don't know if it works yet but will see in the morning Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted August 2, 2017 Author Share Posted August 2, 2017 Worked. Distributor was 180° wrong though so had to reset it. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
