Okay so I'm almost done with my motor swap. I went from a 1988 mj 2.5 5spd 4x4 to a 4.0 aw4 4x4 from a 91 mj. I have swapped the whole driveline all of the engine bay electrics and the behind the dash electronics. I'm curious about the rear cab harness do I need to swap that one also since it's fuel pump rear lights and b pillar lights or can I change the connector and leave the wires
Yes, you will be fine on the rear lights, but the output from the 88 fuel sender will be of opposite polarity for the 91 fuel gauge, so the gauge will indicate backwards. Do you have the 91 sender you can swap in?
You need to swap in the 91 sender for the 91 gauge. There are only three wires on the 91 sender connector; 12V (Grn wire), GND (Blk wire), and the gauge output wire (Blue wire). Would be difficult to get them wrong. The pumps are the same so use either.
These (above) are the connectors in my 88
And
These (below) is the connector from the 91.
Both are 16 wires total. Can I splice the new style connector to the old wires if so what colors to what
Yes. Below is the 91 rear body connector w. pin functions. You will have to identify the Renix connector wires by function, not just color.Tt8sK2w.jpg
Gray plug
-Orange
-brown/white
-gray/black
-tan
-brown
-black
Black plug
-brown
-black/yellow
-white
-white
-green/white
-orange/black
-pink/black
-black/white
-black
-pink
1991
Black plug
-yellow (same pin as other yellow)
-yellow
-pink (same pin as other pink)
-pink
-blue/orange
-blue/white
-green/black
-orange/black
-brown/blue
-brown/yellow
-green
-brown/green
-blue
-blue/red
-tan
-green/red
That's from the 91 FSM. It's correct for the 91. The colors are in the second column.
1991
Black plug
Pin 1 - green/red
Pin 2 - tan
Pin 3 - blue/red
Pin 4 - blue
Pin 5 - brown/green
Pin 6 - green
Pin 7 - brown/yellow
Pin 8 - brown/blue
Pin 9 - yellow (same pin as other yellow)
Pin 9 -yellow
Pin 10 - pink (same pin as other pink)
Pin 10 -pink
Pin 13 - blue/orange
Pin 14 - blue/white
Pin 15 - green/black
Pin 16 - orange/black
This is the pin # and color from the rear harness in my 1991 as you can see it doesn't match
Which 16-pin connector are you looking at? The one near the cab or at the rear?
The other end of the harness
It's the black 16 pin connector behind the driver side kick panel below the parking brake assembly that connects the rear part of the harness to the dash section
So I did all the splicing today so far the rear speaker work the fuel pump n fuel gauge work as well as my rear running lights but I have no brake lights or rear turn lights
