Double Six Posted July 26, 2017 Share Posted July 26, 2017 Hey Guys, I have a new battery ,when you first turn on the ignition to turn over engine it is real slow almost like a dead battery but then kicks in and spins really fast like it suppose too. any ideas as to what my problem may be ? thanks :???: Link to comment Share on other sites More sharing options...
MuddFoot Posted July 27, 2017 Share Posted July 27, 2017 Starter dragging I'd replace the starter Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 27, 2017 Share Posted July 27, 2017 Poor connections, corroded cables, poor ground to block. All your connections need to be shiny & bright & tight. Also, the cables may look OK, but if they're old, they could be internally corroded. Squeeze the cables, see if they sound/feel crunchy. Check the block ground, to see if it's clean and tight too...at the block. How old is the starter? Are all the starter connections bright and tight, especially the little green wire. Link to comment Share on other sites More sharing options...
Double Six Posted July 27, 2017 Author Share Posted July 27, 2017 No,the only ones that are shiny are the ones that are connected to the battery. Starter is old. I;ll try clening up cables ,but i'm thinking it may be the starter . I have had truck for a year and a half and I know it sat up for 3 years before that. Link to comment Share on other sites More sharing options...
omega_rugal Posted July 28, 2017 Share Posted July 28, 2017 drop the starter, disassembly it and check the carbon brushes, replace if worn... Link to comment Share on other sites More sharing options...
