Keith Posted July 17, 2017 Share Posted July 17, 2017 1989 4 L. Manual 5 spd., what is the correct way to hook up a Remote Starter Switch? Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 17, 2017 Share Posted July 17, 2017 You can mount a momentary switch on the dash. You can use a handheld momentary switch. 12v to the small post on the starter. Or, you can use a 4' test wire with an alligator clip at each end, attach clip to small post, touch other end/clip to the pos post of the battery. This is a test for a bad NSS that takes just seconds to perform. Link to comment Share on other sites More sharing options...
omega_rugal Posted July 17, 2017 Share Posted July 17, 2017 Hook 1 cable to the 12v post, another to green wire that goes to the starter just make sure you use a switch that won`t accidently trigger itself with vibrations or one you can accidently trigger while workign on the engine Link to comment Share on other sites More sharing options...
Keith Posted July 18, 2017 Author Share Posted July 18, 2017 Thank you, the green wire did the job. Have a Bosch FIX 7853 Remote Starter Switch. Link to comment Share on other sites More sharing options...
