Aw4 help
So I'm swapping in a 4.0 from a 2wd 1996 cherokee as well as the wiring from the cab forward with a gauge cluster from a 92. My comanche is a 4wd 1990. Both are aw4's, but which transmission should I keep?
Well the engine along with little things here and there, I have the whole cherokee so is there any electronics on the HO tranny that I can swap onto my old tranny to make it work with the tcu?
A 2wd transmission will not work with a 4wd transfer case.  The tranny and the engine MIGHT bolt up, but you won't be able to put a transfer case on the end of a 2wd tranny.  You need a 4wd tranny.  End of story.
