Taillight wiring again.....
I bought a rear harness off ebay a couple months ago and went to put it in finally but the connectors are different and theres a random black wire thats exposed. The wire ties in with the rest of them but theres nothing else for it to go to. Anyone know what wiring I bought? The square connector came with the truck when I bought it, the flat connector is the new harness. Do the two plugs connect?
It's most likely the ground wire and goes the the ground point behind the left tail lamp.
There is an eyelet for the ground. I'm going to pull the loom and compare wire to wire tomorrow morning
